1. sintos
  3. Tuesday, 13 January 2015
Is it possible to make the background of the mainbody (articles + modules) semi transparent ?
Kind regards
Yannis
Hi Yannis
Try adding the following to the Custom CSS field of your templates parameters (edit to taste)...
#container_main .wrapper960 {
background-color: rgba(255, 255, 255, 0.7);
I need onew more think.
The padding of the logo from top is set to 32px.
How can i set this with custom css to different size?
Not sure if I understand you correctly. The position of your logo can be edited from within the 'Logo' tab of your templates parameters. Would you have a URL to an example of the padding in question?
