1. Krumnow
  3. Monday, 15 October 2018
when I set PHP version 7.1 or 7.2 with letterpress template I get in one side (shop system joomshopping) the error: using $this when not in object context... At the moment I use php 7.0 on my website and the latest template letterpress, and the newest joomla and shopping system. I have delete nearly all of unused plugins and modules. With other templates my side is running. So I think the reason for the error could be the template. I ask also the developer of joomshopping about php 7.xx. Could you tell me: Is letterpress compatible with php 7.xx or.. If I would send you my access to my site are you able to set the php 7.2 by yourself or have I to cange from 7.0 to 7.xx? If I have to set the php 7.2 then no customer can buy during the time of you test. Thanks and best regards, Sven
  1. https://www.reine-leinoelfarben.de/de/
Hi Sven
