1. cronopio
  3. Tuesday, 17 September 2019
I have Layerslideshow module on Jasmine template. Everything works fine except the links: I added the URL's in the "slide link" fields of each slide, but it seem to have no effect: slides are not clickable. YOu can check here.
Can you please help?
MArco
  1. http://lalineascritta.marcoalfano.eu
Hi Marco
To amend could you try adding the following to the Custom CSS field of your template settings..
.slidelink {
position: absolute;
height: 100%;
width: 100%;
background: red;
top: 0;
Added the code, now the links works but the images are not shown anymore, replaced by a red block :o
I removed the line
background: red;
And now it works.
Marco
Excellent...thank you for the update and for sharing your solution.
Ciaran,
I installed the Jasmine J51 layer-slideshow in a J51LifeStyle template. Works fine except for the links, even with your earlier tips it's not working?
Is this even possible?
Johan
Hi Johan
