1. mrtmd
  3. Monday, 25 March 2024
When there is more than one slide, slideshow slides partially overlap.
Navigation between slides also doesn't work.
  1. https://dobelespartneriba.area.lv/
I sent the credentials this morning.
While this is being investigated, is there an option to downgrade the LayerSlideshow to the previous version?
In https://www.joomla51.com/forum/layerslideshow-animations-don-t-work it is suggested that the previous version works as expected.
We do not appear to have received any access details related to this item. Could I ask you to resend your details. For our reference please paste a link to this post in your email.
In the meantime could I ask you to try installing the attached which resolves the issue in the mentioned post.
I sent credentials again. To [email protected] from [email protected].
I also installed your attached package. The package installed without issues and showed an info block (something about template overrides). Unfortunately the slideshow in website still appears broken.
I tried to reinstall the theme and the slideshow module. No luck.
The browser console shows error:
Uncaught ReferenceError: exports is not defined
<anonymous> https://dobelespartneriba.area.lv/media/mod_j51layerslideshow/js/tiny-slider.min.js?7b39b2:3
For some reason, the Slideshow in https://dobelespartneriba.area.lv/ is working now.
My first thought was that Joomla51 team had come and fixed the Slideshow, however Joomla user management panel shows that nobody else (except me) has ever logged in.
I can assure that 12 hours ago the Slideshow was broken, but is working now. I have done nothing.
Are there some external dependencies that were fixed today?
Thank you for the update.
That is rather strange. There has been no updates done to any external sources. If the issue returns, let us know and we will take another look.
