1. Drew
  4. Sunday, 10 March 2019
Good day Ciarán,
How might the slide caption be able to move or float more to the left or right when the module width of the position is 100%?
When at 100%, it is a bit farther from the edge prior to the screen size being reduced to smaller sizes.
Thank you - Drew
Hi Drew
.layerslideshow .info {
width: 100%;
Wonderful!!:D
Thank you!! - Did exactly as needed.
Had I noticed before, I would have asked then....
Is it an option to change or reduce the padding around the text also?
Good job on the template Noami!
Ciaran,
h3 font to white SOLVED
in the Module Class Suffix, entered: text-light
2nd question in Addition to the one above - I was trying to change the Font Color on One Icon Module Only.
And not having success using Class Header. I've placed One Icon Module into an area with a black background and would like to change that One Icon Module Only h3 font to white. The current color is hard to see.
I do not want to change Every Icon Module - Just the One Currently with a black background.
I was able to change the "Icon Description" with this:
<p style="color:white">Your home should be a Joy to Live in and a Pleasure to own.</p>
Thank you - Again for answering these 2 separate questions above.
- Drew
Hi Drew
To amend the padding around the slideshow text you can use the following Custom CSS (edit to taste)..
.layerslideshow .info-wrapper {
padding: 20px;
Hi Drew
Would you have a URL to an example of the icon in question?
Solved.
Thank you.
Ciaran ,
Thank you for the padding info!!
Keep up the good work - Awesome Templates!
- Drew
