1. falcongr
  3. Friday, 27 March 2015
I have put the language switcher at the header-1 position at the lifestyle template but this module position is not visible when enter the responsive mode( visiting the site form a tablet or a mobile). How can i fix it.
Thank you in advance
To ensure this module position appears on all screen sizes, try adding the following to the Custom CSS field of your templates parameters...
#container_spacer1 {
display: inline !important;
Now the language switcher is visible at the responsive mode but it is not working as if you try to click any of the flags you can;t as it is a part of the header and it directs you to the homepage.
You can check it at http://weblime.gr/shine. I have disabled the custom css code you told me as it gives me the error I described.also I found another issue when you visit the site from a tablet or a mobile if a menu has a submenu you can't visit the primary menu destination as it is not clickable ( take a look at blog )
Could you try ammeding your Custom CSS to the following...
[code[#container_spacer1 {
display: inline-block !important;
}[/code]
Regarding your parent menu item issue, may I suggest the following post... http://www.joomla51.com/forum/8-commercial-templates/5991-enlighten-mobile-main-menu-not-fully-functional#13254
Thank you very much , now it is working ok.
