1. apelsinskal
  4. Saturday, 14 July 2018
Hi, I am trying to turn off the header module so the slideshow will be hidden on mobile devices. It doesn't seem to work in this template, do you know if there is an error? Working on localhost. Skärmavbild 2018-07-14 kl. 10.34.17.png Skärmavbild 2018-07-14 kl. 10.34.26.png
Hi Ciaran, I have the website on local host at the moment. I will get back to you after I have published it.
Hi Ciaran, I have sent you the login details now.
I believe I now understand your issue. The mobile hide switches are for the header-1 and header-2 module position which does not include the slideshow. To hide the slideshow on small screen devices try adding the following to the Custom CSS field of your template settings...
.vegas-slide {
display: none;
Edit screen size (767px) to your own taste.
Can I turn the slideshow module off totally for small screens?
.vegas-slide {
display: none;
#container_header {
min-height: auto;
height: 200px !important;
Note you may need to change the 200px to best suit your own logo.
