1. niko7488
  4. Monday, 05 February 2018
In the application screenshot from the site.
Help to adjust the distance between paragraphs and modules. For example, the distance from the title to the text is very small. And vice versa, the distance between paragraphs is very large. Template beautiful, but the distances to all ports.
Thank you in advance.
  1. http://pflege-curamed.de/pflegegrade.html
Hi Niko
As your site is offline please send temp account details to info@joomla51.com so we can access your site. Please include a URL to this post in your email for our reference.
A live example of the issue allows us to test the best solution for your issue. This is not possible with screenshots
You can reduce the spacing after paragraph tags by adding the following to Custom CSS field of your template settings (edit to taste)...
p {
margin-bottom: 1rem;
To reduce the space between side column modules you can also add the following (edit to taste)...
.sidecol-a .module_surround,
.sidecol-b .module_surround {
padding-bottom: 20px;
