1. sdassociates
  3. Wednesday, 28 March 2018
I've installed Solidres booking system with the Kinvara template and am having some font issues with Solidres. I've contacted them and they tell me the issue is with the template. The issue is that the Solidres component contains a number of drop-down options, e.g. Number of rooms, number of adults etc. which are selectable from a list. These drop downs and the list when it's displayed only show the upper 20% of the writing with white space where the rest of the letters should be. Can you please advise how I can get the fonts aligned between the template and the component? Thanks.
To amend try adding the following to the Custom CSS field of your templates parameters (Extensions -> Templates -> [YourTemplateStyle] -> Custom CSS)...
.row-fluid [class*="span"] {
padding-bottom: 0;
Perfect. Thank you very much.
Here's the URL: https://sdassociates.com.au/index.php/website-design/demo
You need to SELECT one of the rooms, enter the from and to date and click SEARCH. You'll see the font in the drop-down only partially displayed.
