1. maggo28
  3. Sunday, 29 September 2013
Hallo,
I had a Problem with the Kindle theme what I bought today.
The FierBug console in Firefox told me the following error:
NS_ERROR_XPC_NOT_ENOUGH_ARGS: Not enough arguments [nsIDOMWindow.scroll]
$(window).scroll(function(){
I use the Joomla 3.1.5 version. I think there is a conflict with mootools and JQuery.
What can I do?
The contact form is not working correctly with the slide effects becaus this error.
Thanks and regards
Marco
Hi Marco
We have updated our Kindle template which should amend this issue for you. Simply re-download your template and re-install it via your Extensions Manager.
Hello ciaran,
thanks for the quick help. There is no more error in the FierBug console.
There still be a problem with the context menu, wehre i can print or edit the page.
If I click on the button then the page is loading again and shows no context menu, these problem still be on the external installation. On my local test enviroment this problem is not available. I have no idea why.
About my installation:
- I use htaccess for SEO urls
- I installed these plugins
- Easy Google Analytics
- Xmap - Content Plugin (sitemap.xml)
Do you have any idea why this might be?
Thanks and regards
Marco
Hi Marco
Hello Ciarán,
I send you an email.
Thanks and regards
Marco
Thank you Marco
Te issue appears to be related to your Google plugin as disabling this plugin resolves the issue. May I suggest adding your analytics code either just before the closing </head> tag in your templates index.php (../templates/j51_kindle/index.php) or use the Custom Code fields within your templates parameters.
Hello Cariá,
thank you so much for your help.
Marco
