1. bludove
  4. Tuesday, 17 April 2018
I'm using Kaylee template with GuruPro component.
I was experiencing a problem on my site with the links on this page not opening and just popping me to the top of the page - http://studypercussion.com/index.php/concert-percussion/guruPrograms/2-concert-percussion/6-snare-drum#
Just go down to the Contents tab of the course and click on "what is a snare drum"
I contacted support for Guru Pro and they told me it was a problem with the template - that there is a conflict. So I switched to the default Joomla template (protostar) and sure enough it works like intended but as soon as I switch back to Kaylee it doesn't work anymore. I would very much like to use the Kaylee template so I was wondering if you could take a look and help me get things fixed.
Website is: http://studypercussion.com
I can send login credentials when you need them.
May I suggest the following article on resolving JS conflicts.. https://joomla51.com/tutorials/item/resolving-javasript-errors-in-joomla-using-jquery-easy
Failing that, may I suggest sending temporary administration access to your Joomla installation to [email protected] and we will examine this issue further. For our reference please paste a link to this post in your email.
That seems to have resolved things. Thank you. :D
