1. graphicdetails
  3. Wednesday, 07 May 2014
Please help! Running several galleries on this site and getting fatal error in thumbs gallery.
site is: http://www.excaliburcustomhomes.ca/index.php
error occurs on page: http://www.excaliburcustomhomes.ca/index.php/residential-homes-gallery/bowen-road
Fatal error: Class 'JFile' not found in /home/excalib/public_html/modules/mod_j51thumbsgallery/helper.php on line 29
Have updated module with latest version from your downloads.
Using joomla 3.3 and php 5.3.28
May I suggest re sending temporary administration access to your Joomla installation to [email protected] and we will examine this issue further. For our reference please paste a link to this post in your email.
I noticed that the thumbs were working on the home page. I was using a loadposition in an article for the thumb galleries that were getting an error. I changed the modules to show in position ContentA Bottom on the article pages instead and the galleries showed correctly.
The 'loadposition' suddenly stopped working last Friday. I will send you a login anyway so you let me know where the conflict is.
thanks,
K
I have been trying to replicate this issue locally in an attempt to find a solution however I am unable to do so. If you wish you can send us temporary FTP access to the module folder of your Joomla installation and we will see can a solution be found by editing the thumbs gallery core files.
  3. # 3
Hi Ciarán,
The same problem wiht a Loadposition for the J51-slideshow module.
I´ve moved the module to another position (without the use of loadposition) and It´s OK now.
Has it anything to do with the upgrade to J3.3.0 I did yesterday?
Good luck!
  3. # 4
I will not use the loadposition for the galleries for now.
thanks,
K
  3. # 5
Hi GF
I don't believe upgrading to 3.3 would be related to your issue.
You could try using 'Modules Anywhere' (http://extensions.joomla.org/extensions/core-enhancements/coding-a-scripts-integration/embed-a-include/6402) which usually resolves any loadposition related issues.
  3. # 6
