1. nfaust
  3. Monday, 21 October 2013
Hi.
I bought the template J51 Piano Forte.
I duplicated de module J51 Thumbs Gallery and i want to insert it in a content page using the {loadposition myposition} sintax. I'm using Joomla 3.1.5.
But.. there is a problem: it appears a blank page.
In joomla 2.5 everything worked well.
Can someone help me solve this problem?
Could you check for us that the 'Content - Load Modules' plugin is enabled in your Plugin Manager.
Hi.
'Content - Load Modules' plugin is enabled.
If i disable it, the page shows the code {loadposition test}. If i enable it a blank page is shown.
I created a custom HTML module, for testing purposes and evrything works fine.
Maybe there is some conflict with the module J51 Thumbs Gallery.
Regards.
  3. # 3
I have updated your ThumbsGallery module, removing the following from your modules helper.php (../modules/mod_j51thumbsgallery/helper.php - line 26) which has resolved the issue...
$lists[$i]->title	= JFile::stripExt($file);
  3. # 4
Hi Ciarán.
Thank you very much. Nice job. :)
Best regards.
  3. # 5
