1. jfernandes
  3. Wednesday, 30 October 2013
The images in the j51_Slidshow can't be viewed in a tablet.
It's possible to change that?
The slideshow has been test on most tablets and to date works without issue. The slideshow uses the SlidesJS script (http://www.slidesjs.com/) which is fully compatible with smaller screen devices.
In the website http://www.jpleitao.pt/index.php/en/ i can´t see the images in the slidshow.
what do i need to do to see the images like in the demo. homepage complete images and in the other pages part of the image.
Could you detail for us in what way you are currently seeing your images on your tablet and what tablet you are using (inc. OS version).
The tablet is a BQ Edison with android 4.1
I have the same problem using chrome in my machine. Using iexplorer and firefox works fine
We are able to replicate the problem using Chrome. May I suggest sending temporary administration access to your Joomla installation to [email protected] and we will examine this issue further. For our reference please paste a link to this post in your email.
I already sent you the administration access
The issue appears to be only present on your homepage with the slideshow working fine in for example here... http://www.jpleitao.pt/index.php/en/about-us/historial
This would suggest that there is a conflict with one of the modules on your homepage. Try disabling each of your homepage modules one by one until the slideshow functions to find out which module is causing the conflict.
We were unable to try this ourselves as caching is turned on which you will have to disable first.
