1. crimle
  4. Friday, 19 April 2024
I have an issue with the 2-columns blog-layout under J51_Skylar_1.1.14. The first column is ok. But the second column does not respect the max-width of the template. The second column extends beyond the right-hand edge of the template.
This issue is similar to an issue with J51_Enterprise I reported earlier. So I tried the solution you provided in that thread and it works :-) I added the following to the Custom CSS field of the templates parameters (Extensions -> Templates -> [YourTemplateStyle] -> Custom CSS)....
.blog-items.columns-2 {
grid-template-columns: 50% 50%;
.blog-items.columns-3 {
grid-template-columns: 33% 33% 33%;
I just wanted to let you know in order to apply this to a future version of the J51_Skylar template.
Thank you and kind regards
Chris
