  1. gcopping
  4. Thursday, 31 March 2022
http://www.joomla4.nepal-systems.co.uk/
I am trying to use this extension instead of the layer side show but I can't get it to transition. As you can see at the link above it just puts the 2nd item next to the 1st. I have items displayed = 2 and Autoplay on, but am obviously doing something wrong but can't figure out what - can you please help as I can't find any documentation on this extension?
Thanks,
Gary
Hi Gary
May I suggest sending temporary administration access to your Joomla installation to [email protected] and we will examine this issue further. Previous details sent appear to be no longer valid. For our reference please paste a link to this post in your email.
Thank you Gary
Looking at your example and you appear to have it set to display 2 items per slide however there is only 2 items in total so it never slides. Adding a 3rd item and the rotate appears to work without issue,
Thanks again Ciaran,
Sorry but I totally misunderstood "Items Displayed" I thought it was the total items for the module not just the number of items to display for each slide. So all sorted now.
Best regards,
Gary
  3. # 3
