1. ziggy
  4. Wednesday, 03 October 2012
I was able to set two language options on the top left corner of this template. When clicking on DE to change to the german version of the website, the "Hornav" menu disappears. Under "Hornav Menu Settings" I had chosen the option "mainmenu-es", which would be the spanish version. Is there any way to choose an option that allows seing the "Hornav" menu on all language versions?
Thanks in advance for a quick response,
Regards from Germany
Daniel
Hi Daniel
There is two options available to you. One is to convert the top menu area in to a module position and then create a menu module via your module manager for each of your language. To convert this area may I suggest the following post.. http://www.joomla51.com/forum/support/commercial-templates/hornav-module-not-visible-in-avenue#627
A second solution is to create a separate template style for each language (Extension -> Template Manager -> J51_Resonate -> Save as Copy). Within this style you can then use the menu assignment fields to assign the style to the menu items of a particular language, adjusting the hornav menu to match.
Hi CIaran
I have a working multilang menu now, using the link above. is it possible to convert the "footer menu" (and/or others) too?
Tom
Hi Tom
To convert the footer menu to a module position edit the following near the end of your templates base.php (../templates/j51_resonate/php/layouts/base.php)..
	<?php if($footermenu_onoff == "1") : ?>
<div id="footermenu" class="block_holder"><div class="module_margin">
<?php echo $footermenu; ?>
<div class="clear"></div>
</div></div>
<?php endif; ?>
Change to...
<jdoc:include type="modules" name="footermenu" />
</div></div>
This will convert the area to a position called footermenu.
Hello Ciaran
Was in holidays some time thus the late answer. works like a charm, thank you!
