1. skyd34th
  3. Wednesday, 18 April 2012
J51 - Rendezvous
It is posibble to put custom module in predefined positions in this template (like hornav, search)?
I want to put custom module (VM cart) in SEARCH position.
best regards
In your templates header.php you can try replacing the following in your templates header.php (../templates/j51_rendezvous/php/layouts/header.php)
<div id="search">
<?php echo $search; ?>
</div>
With
<div id="search">
<jdoc:include type="modules" name="search" />
</div>
This will create a module position (search) in place of the preinstalled search module.
thx, Great it's work
Is there any module styling in this template for modules outside main page (modules on wood texture) ?
Hi skyd34th
Do you mean for the search module you have created or the base modules?
Yes.
For example when i publish VM Cart module in base1-a position it's get grey background on wood texture.
When i publish VM Cart in Search position that i created it's have no style - it's posible to turn on this background by Module Class Suffix? or other way?
And if there other, different styling for modules in position like base1 like white bg ?
To edit the base module background you can add the following CSS to the custom CSS field in your templates parameters..
[code type=css]#base .module {
background: #FFFFFF;
}[/code]
Where #FFFFFF is your new background colour.
For your new VM module you can use the following CSS selector to style it..
[code type=css]#search {...}[/code]
