1. kouliss
  3. Friday, 18 September 2015
Hello all.
I am using J51 Polaris. I added a menu item that listings a Contact Category list. In the list Table Headers not showed. When I am using another template (J51 Neptune) the headers showed. Please help.
Use the following url as an example.
http:// http://beta.vwclub.gr/index.php/contact-us-mainmenu-3
There is no table header in your page source which would suggest a Joomla setting issue rather than an issue with the template hiding the header. Have you tried enabling the title within the settings of the menu item linking to this page?
I already enabled the Title setting in the menu item. Also I enabled the Title setting and to Contact Global Options. Any other idea?
Thank you Kosmas
I have enabled the 'Category Title' option to 'Show' in the menu item linking to your contacts pages and your title appears to be now displaying correctly.
I think you didn't understand what I want.
The category title display the category Title above the contact list table.
I want to show (display) the table headers on every column.
The right table (with headers) is http://www.vwclub.gr/index.php/contact-us-mainmenu-3 The headers (titles) are (in Greek Language) Όνομα (Name), Θέση (Position) etc.
The wrong table is here http://beta.vwclub.gr/index.php/contact-us-mainmenu-3
To ensure that the title you wish is outputted by Joomla 3.x, could you try one of the default Joomla templates (Prostar) and see if the title you require exists?
I changed the template for this page to Joola 3 Default / beez3.
The table headers exists and displayed correctly. You can see it in the example URL.
I am still a little confused by this. The same information appears to be displaying for both templates. The information we are seeing for the first entry for example on each template is as follows..
Δ.Σ. Hellenic VWClub
Δ.Σ.
Ζωγράφου, Ελλάδα
Τηλέφωνο : +306999892582
I have added similar values on two different contact entries. The difference is the contact name.
Focus on the table headers and not on the "values" of contact entries. The contact "values" does not affect the table headers.
I am not sure if I understand your query correctly. Would you have a URL to an example of this issue?
Lets start from the begin.
The example url is http://beta.vwclub.gr/index.php/contact-us-mainmenu-3
When I am applying Beez3 default template the contact list has table headers. You can see them on the following image with yellow "circle".
When the J51 Polaris template applied as default the table has no headers.
So, I want to display table headers (in contact list) with J51 Polaris template.
Thanks in advance.
The Beez template uses an override to output the contact table which includes a title. You could try copying this override from your Beez template to your Polaris template. To do so copy the ../templates/beez3/html/com_contact folder to ../templates/j51_polaris/html/. Note the Beez3 contact table is not responsive.
Didn't work.
