Membership ID 6601
1/ purchased novah paid $19 euro
2/ no download link in my downloads list
3/ is listed in purchase history
4/ showing only 1 year usage, not usual 2099 (lifetime)
Thank you for bringing this issue to our attention. The Novah template should be now available for you to download (inc.lifetime availability). My apologies for the delay in receiving your purchase.
yes thank you from all of us here at BareFootTech, Design by Studio51 and our Associates at ZAZU Design. We have developed over 250 Joomla! sites this year alone.
when using the j51layerslideshow the images don't appear (temp fix I installed same module from Jasmine)
plus using j51news modules from the NOVAH template the linkicon is HUGE & appears above image and hover effect does not work
(temp fix removed SVG from link-icon section of default.php)
if NOVAH installed as demoinstall both modules work
needs FIXING ASAP
https://sg7.coreygrosvenor.com/crynetau/
your j51news module installed on a standard Joomla! installation
(error when installing the extension)
Warning
JInstaller: :Install: File does not exist /home/sg7coreygro/public_html/crynetau/tmp/install_5d7b4c502983f/media/index.html
Thank you for bringing these issues to our attention. We have just updated the template bundle, where both issues should be now resolved. To obtain re-download the template from your Joomla51 'Profile -> Templates Downloads'.
Just to mention. To add a page heading just below the main menu (Welcome to Corey.net.au) you can use the Page Heading option in the menu item settings.
