1. crimle
  4. Tuesday, 22 September 2020
I am using «J51_Natalie Example Style 6». The social media icons like «Instagram» are visible on mouseover only. The reason for this is probably the background-color of Example Style 6. Please give me a hint to fix this.
Thank you and kind regards
Chris
  1. https://malix-verlag.ch/de/
Hi Chris
As your site appears to be offline, could I ask you to send temporary access to your Joomla installation to [email protected] and we will examine this issue further. For our reference please paste a link to this post in your email.
Thank you Chris
Can you confirm that the icon color is not set to white in the Social Icons tab of your template settings?
If not set to white, try adding the following to the custom CSS field of your template settings (edit to taste)...
#socialmedia ul li a [class^="fa-"]::before, #socialmedia ul li a [class*=" fa-"]::before {
color: #777777
It works! Thank you Ciaran!
Kind regards
Chris
