1. Kris
  3. Monday, 19 March 2012
J51 - MountainPine
I have two questions (problems) on the template J51 - MountainPine (Joomla 2.5)
1. I use Polish characters (in phpmyadmin I set to utf8_general_ci database). I have a problem when the title of the article puts Polish characters (ę, ą, ó, etc.). Template J51 - MountainPine not see them. The problem affects only the article title. On the other templates in the titles of articles are displayed correctly Polish characters.
What must be set to Polish characters were displayed on a template J51 - MountainPine at article titles.
http://i43.tinypic.com/668z90.png
EDIT: I found that probably corresponds to the lack of Polish characters in the script file: j51_mountainpine/js/cufon.font.js | But I do not know what to change it to have Polish characters (encoding to UTF 8?, Font-family ":" Delicious "does not support Polish characters?). Please support.
2. In the template J51 - MountainPine give you the ability to choose the columns to the left or right.
What and where to modify the columns could be set right and the left in the template.
Hi Kris
1. If you wish you can disable the cufon font used by removing the following from the head of your templates index.php which should amend your issue. This will revert your titles back to the default font which would have a full character set.
<script type="text/javascript" src="/<?php echo $this->baseurl ?>/templates/<?php echo $this->template?>/js/cufon-yui.js"></script>
<script type="text/javascript" src="/<?php echo $this->baseurl ?>/templates/<?php echo $this->template?>/js/cufon.font.js"></script>
Cufon.replace('h2, h3, h2 a:link,h2 a:visited, .contentheading, .sidecol_block h3, .sidecol_block_menu h3, .moduleblock1 .module h3, .moduleblock1_menu .module h3');
</script>
2. You can edit the sidecolumn position via the templates parameters. Navigate to Extensions -> Template Manager -> J51_MountainPine.
1. Fact resulted in the removal of the script to display Polish characters, but unfortunately the font was very ugly.
I found another way to have Polish characters and have a nice font (which they choose) on the template. Just keep in characters (with free license), which supports Polish characters in the format (TTF, OTF or PFB - downloadable example at: http://www.fontsquirrel.com/). That saved the font to be converted to a script file (. Js). On the http://cufon.shoqolate.com/generate/ have read font file (TTF, OTF or PFB) would then generate the font file saved as a script. To get Polish characters, select the options before generating: <Basic Latin> | <Latin-1 Supplement> | <Latin Extendend-A>
The generated file must be renamed to: cufon.font.js
Cufon.font.js (new file), copy (overwrite) to: \templates\ j51_mountainpine\js\Cufon.font.js (old file)
2. Unfortunately it is not possible to select the left and right columns (sidecolumn) at once. In this template, you can have a column on the left or right position.
Unless you would choose such a column on the left side and would be something in the code add template.css file? creating a new Module Positions sidecolumn on the right. ;)
Cheers.
Hi Kris
Thank you for posting your solution to the cufon font issue.
Regarding the sidecolumn modules will you be having both sidecolumns (left & right) present on all pages? I can put together the changes needed if this is the case otherwise the changes would be quite extensive if you wish the module positions to collapse on certain pages. I would also need to know what width you would like the columns as you would no longer be able to adjust the width via the template parameters.
I would ask about the possibility of setting sidecolumns left and right module position (column width 180px) with the possibility of collapse at some sites, due to "Phoca Gallery Tree Module", which would be activated only in menu the "Gallery".
Thank you for your support :)
Hi Kris
Right to start off open your templates index.php (../templates/j51_mountainpine/index.php)and locate the following...
<style type="text/css">
#sidecol {width: <?php echo ($sidecol_width); ?>px }
#content80 {width: <?php echo 865 - $sidecol_width ?>px }
<?php if($this->params->get('col_pos') == 'col_l') : ?>
#content80 {float:right; padding-right:25px; padding-left:0px;}
#sidecol {float:left; padding:0 0px 0 25px;}
<?php else : ?>
#content80 {float:left; padding-right:0px; padding-left:25px;}
#sidecol {float:right; padding:0 25px 0 0px;}
<?php endif; ?>
</style>
And replace with...
#content80 {width:880px; padding-left:26px;}
/*--Check and see what modules are toggled on/off then take away columns width, margin and border values from overall width*/
<?php if($this->countModules( 'sidecol-a') >= 1 && $this->countModules('sidecol-b') >= 1) : ?>
#content80 {width:464px; float:right; padding:0; }
<?php elseif($this->countModules('sidecol-a') >= 1 && $this->countModules('sidecol-b') == 0) : ?>
#content80 {width:670px; float:right; padding:0 38px 0 0;}
<?php elseif($this->countModules('sidecol-a') == 0 && $this->countModules('sidecol-b') >= 1) : ?>
#content80 {width:670px }
<?php endif; ?>
#sidecol_a {float:left; width:220px; padding-left:14px}
#sidecol_b {float:right; width:220px; padding-right: 12px;}
</style>
Further down the same file locate the following..
<?php if ($this->countModules( 'sidecolumn' )) : ?>
<div id="sidecol">
<div class="sidecol_block">
<jdoc:include type="modules" name="sidecolumn" />
</div>
</div>
<?php endif; ?>
And replace with...
<?php if ($this->countModules( 'sidecol-a' )) : ?>
<div id="sidecol_a"><div id="sidecol">
<jdoc:include type="modules" name="sidecol-a" style="j51_module" />
</div>
</div></div>
<?php endif; ?>
<?php if ($this->countModules( 'sidecol-b' )) : ?>
<div id="sidecol_b"><div id="sidecol">
<jdoc:include type="modules" name="sidecol-b" style="j51_module" />
</div>
</div></div>
<?php endif; ?>
After that you will have created two sidecolumn module positions 'sidecol-a' for the left column and 'sidecol-b' for the right column. Note that these will not be listed in the positions dropdown of the modules parameters so simply just type them in to the same field.
Both left and right module positions should be collapsible.
Hi Ciarán,
Made changes to /templates/j51_mountainpine/index.php according to your description.
The changes moved the Joomla 2.5.3 (newly installed).
Modules whose names have assigned positions: Last news (sidecol-a) and Login Form (sidecol-b).
http://i44.tinypic.com/os93c5.png
Unfortunately the modules are displayed above the main content of the page.
http://i40.tinypic.com/qyej9y.png
Do not know if it matters, but in my code that I had to replace one line is slightly different from yours. The code that was in my index.php file:
<div id="sidecol">
<jdoc:include type="modules" name="sidecolumn" style="j51_module" />
</div>
</div>
<?php endif; ?>
<div id="content<?php echo $contentwidth; ?>">
And the code from You, which was to be replaced:
<div id="sidecol">
<jdoc:include type="modules" name="sidecolumn" 15:40 23/03/201215:40 23/03/2012 />
</div>
</div>
<?php endif; ?>
Thanks for your help :)
Hi Kris
May I suggest sending us temp administration access to [email protected] and we will investigate this further.
There was one other amendment I forgot to mention.. replace the following in your templates index.php
<?php
if($this->countModules('sidecolumn') == 0) $contentwidth = "100";
if($this->countModules('sidecolumn') >= 1) $contentwidth = "80";
With....
<?php
if($this->countModules('sidecolumn') == 0) $contentwidth = "80";
Everything should be fine now
Hi Ciarán,
I appreciate your work.
I noticed a small error in the display of the left column (sidecol-a).
Appears only when it is displayed "alone" without the other right-hand column (sidecol-b).
http://i39.tinypic.com/2j47hig.png
http://i43.tinypic.com/5v5e1d.png
http://i43.tinypic.com/vq1n37.png
Hi Kris
Would you have a URL directly to this issue?
Hi Ciarán,
URL: http://mebloplyt-kielce.pl
