1. gregdei
  3. Thursday, 13 September 2012
Hi there,
I updated my site from Joomla 1.5 to 2.5
I got the new 2.5 template from J51 (J51-Motion)
I wiped everything from my server and I added a new database
After installing I miss the left menue. I'm also wondering why the template suddenly appears as a three column layout.
I have an old 1.5 example so as the new 2.5 one
Would be great if someone could help me!
greg
Never mind,
I figured it out by myself - at least the issue withe the left menue.
The module positions were on 5, 6 and 7 after switching them to 'left' everything was fine!
greg
Hi Greg
Would you have a URL to an example of the 3 columns?
Thanks Greg.. your right, it may be time to change the links color on the forum here :)
The homepage of your site is set to a featured articles layout with 3 columns and one leading. To amend this navigate to Menus -> Main Menu -> Home and amend the 'Layout Options' to your own taste.
Hay Ciarán,
thanks, I know how to change the columns. I was just wondering to see the difference between the 1.5 and the 2.5 version - moreover cause there was no menue on the left side!
At first it looked like a redesigned layout!
I appreciate your help very much. Very good support here!
greg
Hello!
I use j51 motion template on joomla 2.5, when switching to joomla 3.9 I would still like to keep this template, how can you help me, or what can i do to make j51 motion template work on joomla 3.9 or advise me to change the template for something similar , which has a similar appearance.
