1. warren0728
  3. Wednesday, 14 March 2012
for some reason when i installed the slideshow module that came with Morpheus i can't set all the parameters including the folder where the images are, etc.
Is Morpheus/Slideshow compatible with Joomla! 2.5.2?
thanks in advance.
ww : )
Could I get you to attach a screenshot of your slideshow parameter settings so we can have a look at how you have it set up.
ok here is a screen shot....it looks to me like i don't have all the parameter settings available?
thanks
It appears you might have the Joomla 1.5 version of the template installed to Joomla 2.5. May I suggest uninstalling the module and reinstalling the mod_slideshow in the Joomla 2.5 folder of your download.
i'm not sure what you mean....do i need a new version of the Morpheus template with 2.5 support?
i used the module that came with the Morpheus template but i don't have a 2.5 version of mod_slideshow?
thanks,
ww : )
Could I get you to email your PO number to [email protected] and we will forward you the latest download of your template.
i'm not sure i have the PO....i bought the template a couple of years ago....i'll see if i can find it.
just sent you the po
hey thanks for sending me the updated template. It's working as it should!
can you recommend a good free lightbox type plugin for the Morpheus template? I guess it would need to be an inline plugin?
thanks again,
ww : )
RTs rokbox seems to be one of the more popular lightboxes we see used... http://www.rockettheme.com/extensions-downloads/club/1005-rokbox
