1. breinicke
  3. Tuesday, 13 March 2012
Since our upgrade to J2.5, the main menu in MonoChrome has not been functioning 100%. Please visit here and mouse through the drop-downs and you'll see how at times a second menu item will also drop down and flicker.
Does anyone have any suggestions on how to fix? Is there a newer version of the template for 2.5 compliance?
Joomla 2.5 uses a newer version of MooTools which is not compatible with the dropdown menu on your old template. An updated dropdown menu has been implemented on the Joomla 2.5 version of the template.
If you wish you can forward the PO number and email address of your purchase to [email protected] and we will reply with the latest Joomla 2.5 version of the template. Alternatively I can detail for you how to upgrade the template manually here.
This is the same bug I am also facing..But along with it I also have one more issue and that is I lost my PO number..Now what should I do??
If you could mail us the email address used with your purchase and the name of the template we can look up your PO number on this end.
Sure Ciaran will mail it to you and thanks for showing concern..
Thank you for your great customer service! The site is working great now.
