1. Faber
  3. Tuesday, 12 May 2020
Good morning, I installed the j51 menu restauranrt. Is it possible to make sure that a User with front end permissions can only see and modify the part of the module that compiles the menus?
Thanks.
By default, Joomla does not have the option to serve a segment of a modules options. One workaround is to simply hide certain options using CSS from front end editing. This CSS can be added to your frontend template.
May I suggest sending temporary access to your Joomla installation (as user that can edit frontend) to [email protected] and we will examine this possibility further. For our reference please paste a link to this post in your email.
