1. magsmag
  3. Wednesday, 04 March 2015
Just installed jlifestyle template and i would like it to look like style 1
how do i change it to syle 1 cause it appears tobe style two
Hey Mags,
You'll want to go to Extension -> Template Manager at the top and then use the "Default" star option to select your style, see the attached photo.
thx for the reply but i don't have that option here is the way it looks.
Oh sorry, Ciaran will have to answer you as I don't own that particular template :)
To make available the demo template styles as kindly listed by Arconis you will need to install the 'Demo Installer' included with your download. This is a copy of Joomla with the template demo content included as part of the sample data. Details on installing the demo installer can be found at the following URL... http://www.joomla51.com/tutorials/item/setting-up-the-demo-installer
Alternatively you can simply set up your template styles as showing in the following screenshot. A copy of this screenshot can be found in the 'Template Extras' folder of your download.
That's the five time i have installed the 'Demo Installer' included with your download
J51_Lifestyle_DemoInstaller_J34
I have tried everything and it still does not look as aarconis'
The only reason i bought it was because of style one as it suited my needs am really frustrated and almost giving up.
I have noticed that the template is not showing at the back end although it has been installed have a look at the snapshots
Could you kindly help?
thx
Can you confirm that you have followed all the necessary steps details at http://www.joomla51.com/tutorials/item/setting-up-the-demo-installer in setting up the 'Demo Installer'? One common mistake is failing to select 'Default English (GB) Sample Data' under 'Install Sample Data' on the 3rd step of your Joomla installation to import the demo content for your template.
thx
I have done that but still it does not work.
Could you provide any more details on the issue. Any install errors or database connection issues when install the demo installer?
no there were no errors during the installation.
Could i send you the details and maybe you could have a look cause i have tried everything.
thx
Details can be sent to [email protected]. Please paste a link to this post in your email for our reference.
