1. pitzerwm
  4. Friday, 27 July 2018
Kinvara Template. For some reason the slide caption 's default white color is being over written to black.
Update: I just tried to change the default White Title color in the module and it won't change, this might be another clue.
Here is my custom css, in space not a file.
.layerslideshow .NextArrow,
.layerslideshow .PrevArrow {
background-color: rgba(255,255,255,.2) !important;
.layerslideshow-title {
font-size: 20px;
font-family: "Arial" !important;
.layerslideshow-caption {
font-size: 20px;
font-family: "Arial";
.layerslideshow.module594 {
max-height: 640px;
overflow: hidden;
#container_showcase1_modules .wrapper960 {
background-color: transparent !important;
.flexgallery figure::after {
display:none !important;
.logo {
padding-top: 0px;
padding-bottom: 0px;
.menu {
padding-top: 0px;
li.item-101 {
display: none !important;
.hornav > ul > li > a {
font-size: 16px !important;
.hornav > ul ul a {
I added font-color: "White" & color: "White" Looking at the page execution code, there is an "invalid property value" flag whether I use font-color: "White" or color: "White" I tried color: "#ffffff" AND that worked!!
BUT why was it being overwritten, without the custom css is the question?? You have had to tweak this module a bit, could have messed this up?
I have Custom CSS file load turned off although there is nothing different in it.
Hi Bill
Kinvara, sorry
Update: SUDDENlY the Slide Title and caption are now following the setting in the module. I had set the Title to be Blue, just as a test and it stayed White. All that I had done was installed the free version of Advance Module Manager. I was waiting for you to take a look at this.so I wasn't messing with the settings.
  1. http://midcolumbiawoodturners.org
We are unable to locate access details for this site. May I suggest sending temporary administration access to your Joomla installation to [email protected] and we will examine this issue further. For our reference please paste a link to this post in your email.
sent, but this seems to have magically fixed itself.
Ensure you have caching disabled. You can always turn it back on once your site has been launched. Also ensure you do a full refresh on your browser after any changes.
I checked Global Config. > System > System Cashe = OFF - disabled
I've been in computers a long time and although logically it's impossible for something to magically fix itself, BUT we have all experienced the SUDDENLY it worked!
Thanks for your time.
