1. Essentee
  3. Monday, 28 November 2022
Hi. Just purchased j51_kaylee for Joomla 4.
The custom.css feature is broken. I've tried placing custom.css in the /templates/j51_kaylee/css folder as per the J3 days and also in the media folder under
\media\templates\site\j51_kaylee\css
Neither one works - It simply doesnt load. How are we supposed to use custom.css?
Tony
Hi Tony
Well..... This developer feels like a right tit!
Solved the problem. I had a cache plugin enabled in my dev server (Specifically the RSSEO system plugin, which i usually remember to turn off in Dev sites for EXACTLY this reason.) Turning that off made things work as expected.
<Slinks away with tail between legs>
Tony
HI Tony
Great to hear you found the solution :) Thank you for the update.
