  1. gcopping
  4. Thursday, 22 October 2020
I have added twitter and facebook url's in the Social Media tab but the icons are not displaying in the header. Have I missed something on how to activate these?
Thanks,
Gary
Hi Gary
Hey Ciaran,
I am having this exact same issue with Jasmine. Can you direct me on how to fix it. You know me, I have been a client for of yours for 10 years. I have tried everything to fix it to no avail.
Kindest regards,
JT
Hi JT
HI JT
This issue should be now resolved. As you appear to be using FA5, I have added your icons via the custom option.
Yeah, that worked, but now some of our other FA icons on our services and industries areas in the bottom module are showing as a rectangle now.
Check that all your icons are using the FA5 syntax. FA5 requires and addition fab class (brand icons) or a fas class (solid icons) along with the standard icon class.
Did you see the FA code I added in the Custom Area?
Thank you. To amend try adding the following to the Custom CSS field of your templates parameters (Extensions -> Templates -> [YourTemplateStyle] -> Custom CSS)....
[class^="fa-"]::before, [class*=" fa-"]::before {
font-family: "Font Awesome 5 Free";
font-weight: 900;
