1. ohial
  3. Monday, 11 May 2015
Hi, I want to add a banner type logo to the very top of the page and have a seperate nav bar at the bottom of this. I have created a new module with image but I can't get it to display at the very top of the page. Pls help
Thanks so much for all your help Ciaran.
Your only real option would be something like the following (Custom CSS field)...
#body_bg {
padding-top: 100px;
.logo a {
left: 0;
top: -114px;
Ok will do right away
Hi Ohial
If you wish to enable the Grafik template, we are here to have a look for you (http://gemuk.org/).
I tried that but it ends up...... well pls have a look
Admittedly this might not be the ideal template solution for what you want to achieve, regardless..
Have you considered simply using the logo image option in your templates parameters to add your banner? It will need some custom CSS however might be an easier solution for you. Place your banner using this field then we can take a look and see can amend to your taste with some CSS.
Thanks Ciara,
this is the url: http://gemuk.org/
Just to mention I'm new to Joomla but moderately familiar with html & css.
What I'm trying to achieve is to get the banner-type image logo to be at the very top of the page and have the navigation bar below it.
I also want to get rid of the text logo.
I appreciate your quick response.
Would you have a URL to an example of your issue?
