Hi. I upgraded my website from Joomla 3.x to Joomla 4.x and installed the j51_Everly template for Joomla 4.x but the 'Showcase' is not loading properly (see attached image).
It did change but not as it should be. The slideshow does not cover the whole width and the bottom curve is not there. The top bar/menu is fixed above the image and not showing as per template (see attached image)
In the Module Widths -> Showcase 1 Modules tab of your template style settings, I have set the Remove Container Padding option to no. Your slideshow module should be now displaying as in the template demo.
