1. castellodipavone
  3. Wednesday, 20 January 2016
using J51 Enlighten (ver 1.2) on Joomla 3.4.8
site address: http://www.agiodice.net
I would like to add a module position in the header on the far right, just to add Google translator selector.
I try the procedures in J51 tutorial area but there is no search module and also the header.php code is different from the tutorial example.
Can you help me?
Many thanks
I bought j51 executive and want a module position in the right top corner for language switcher. I tried https://joomla51.com/tutorials/item/creating-a-new-module-position-in-the-header-area-of-your-template this method with no luck. Could you tell me what is wrong.
This was just a test module we created which i believe we called 'test module'. Simply disable/delete this module via your 'Module Manager'.
Thanks Ciaràn,
very kind as usual.
I use the position "newmodule" and it works. The only problem now is the string "newmodule position" (see attachment).
How can I wipe out it?
The new module position has been created for you. This module position has been positioned by adding the following to the Custom CSS field of your templates parameters (edit to taste)...
#newmodule {
position: absolute;
right: 25px;
top: 25px;
