1. EFH
  4. Thursday, 05 February 2015
Hi There,
I have created the grid gallery, however, I am not sure how to add the text and header box under the image and not on the image, like the demo template (photo attached) It works in responsive mode but not on desktop? Would you have J51_ImageLinkHover for Joomla 3? or how do I fix this?
Also how do I make all the images the same size in grid gallery?
Thanks in advance!
Ensure you have the GridGallery extension installed that was included with your template as styling for the extension varies from template to template which I suspect may be the issue here?
Thanks for your reply.
I have uninstalled the grid gallery module and the thumbs gallery module. I have tried to install both extensions and even though it says that it has installed, neither of them appear in the module manager or have been installed. I'm totally confused now :unsure:
Hi there,
I have worked it out and needed to go to extensions - manage and uninstalled and re-installed the grid gallery and thumbs gallery with the correct extension for Classic. However, the grid gallery is still not working correctly on desktop only in responsive and the text is still appearing on the image. Any suggestions?
  3. # 3
  3. # 4
I have sent the details as requested.
  3. # 5
I have checked your GridGallery module and it is working correctly. I have edited the colors to match that of the template demo... http://www.joomla51.com/demo/0115/
  3. # 6
That's Perfect! Thank you.
  3. # 7
