1. crea
  3. Monday, 07 December 2015
Hello Joomla51 Team,
I use the template Enterprise with the J51_Carousel Template.
I activated 14 columns (all).
Then I get the following error:
Undefined offset on line /modules/mod_j51carousel/tmpl/default.php line 96 and line 99.
If I only activate the columns until 12 then everything is fine, the error only occurs if i activate the columns 13 and 14.
I hope you can help me!
Hi Crea
Thank you! I will upload it to my webhoster an send you an email!
Thank you for your quick answer ! :)
I have the same problem was there a fix for this. both column 13 and 14 will not work but all others works fine.
Hi quickchilli
On which template are you having this issue?
running on template J51_Alexis -
This issue so be now amended in the lasted download of the template. Simply re download the template and install the carousel module via your extensions manager to update.
I have downloaded and installed both template and module but I still have the same issues.
Both column 13 and 14 appear to be now working without issue?
