1. ziggy
  4. Wednesday, 09 May 2012
Hello.
I've tried to install the GoogleMaps plugin to put a map in a website with J51-Arabica Template.
I've insert this in an article:
{mosmap lat='<latitude>'|lon='<longitude>'|zoom='3'|zoomType='Large'|zoomNew='0'|mapType='Satellite'}
but doesn't work.
If I try with the Beeze2 Template (default in Joomla 2.5) the plugin perfectly works, and I can see the map, as you see in the image on the bottom. So the problem is into the Arabica Template code.
So, what can I do?
Thanx, Salvatore
Hi s.leo75
Are you having similar issues if you use Googles iframe option to embed the map?
If you wish you can forward temporary administration access details for your Joomla installation to [email protected] and we will investigate the issue further.
Is the problem already solved?
I have the same issue when I use iframe option (Neptune template).
No, the issue has not been solved yet.
I copied the HTML code in a HTML file. But I have to copy again when I change something as menu item or something else.
Hi Feri
