1. Lisbeth
  3. Monday, 23 January 2023
Hi!
I just bought the scarlett template. installed it on a test server to try it out. On the very top, header? there is a single line with the writing ?> top left corner of the page. Doesnt seem right that it should be there.
I would also like this header line not showing, can this be done?
I dont know how to write code at all, but i like this template and i think i can make it work for me!
Another question is, is it possible to make the menu text larger on pc? Most of my customers are elderly....
To amend the main menu parent item size, try adding the following to the Custom CSS field of your templates parameters (Extensions -> Templates -> [YourTemplateStyle] -> Custom CSS)....
(edit to taste)
.hornav > ul > li > a {
font-size: 18px;
Thank you!
All problems solved!!
