1. MessieAss
  3. Monday, 16 January 2023
Hello!
I'm about to set up a J4 Website with J51_Stella template. The site almost looks like i want to have it (at least according to my expectations after a few minutes of work.)
However there's info displayed above the articles that i want to hide. Sounds simple because of the options in the backend, however:
No matter what i try to hide, it all still shows up on top of the front end: Author, Category, Hits. Whatever i configure in the article config or the template, that line won't disappear. Am i missing something?
System is a very fresh install of Debian 11 with Apache 2.4.54 and PHP8.1.
Affected website (under construction): http://www.nahtreich.de
From your Joomla administration, navigate to Content -> Article -> Options, under the 'Articles' tab, you will find a number of options to enable/disable this information. These settings are your global settings but can also be set on a per menu item or article basis.
I hope this helps.
Oh thanks a lot! That helped! :D
I seem to have ignored that specific button pretty thoroughly. I have been administering linux servers ever since, but Joomla has not been my main playground.
Thanks again!
