1. smithjd44
  4. Wednesday, 07 September 2022
I am currently converting the website at the link https://visionbeautyinstitute.org which is a Joomla 3 using the Everly template.
You provided me the following code
@media only screen and (min-width: 1080px) {
#container_showcase1_modules + .content_main {
z-index: 50;
.showcase_seperator {
z-index: 40;
to expand the image in the showcase 1a position.
That worked well with the Joomla 3 version of Everly.
I am currently converting that website into a Joomla 4 using the Joomla 4 version of the Everly template.
That website is on a temporary domain at http://tempdomain82.site.
I have copied the code above into the Joomla 4 version of the template but it appears to have no affect. On the mobile view it cuts off almost all of the bottom half of the image.
Thank you in advance for any coding or suggestions that could fix the image in the showcase position for the Joomla 4 version of the website!
James
  1. https://visionbeautyinstitute.org
  2. http://tempdomain82.site
Hi James
To amend try also adding the following to the Custom CSS field of your templates parameters (Extensions -> Templates -> [YourTemplateStyle] -> Custom CSS)....
@media only screen and (max-width: 1180px) {
margin-top: -100px;
