MENU
  1. soypia
  3. Tuesday, 05 February 2019
hi. it seems that the theme does not work as it should.... The slider is under the header.
https://www.joomla51.com/demo/#hayley
You can also check your demo. Could you please find a solution?
This is actually by design however the option is available to disable it. Navigate to your LayerSlideshow module settings (Extensions -> Module Manager -> [YourLayerSlideshowModule]) and in the Settings tab set the Overlap Header if in showcase-1# module position option to No.
