  1. timpick
  3. Tuesday, 21 January 2020
I can’t change module position using iPad.
Not sure if Joomla, iPad or template problem
Can you help
Tim
Hi Tim
Are you having this issue in the frontend or the backend? If the frontend, is the same issue present if using the default Joomla template (Protostar).
Hi, thanks for reply.
All seems to have been sorted now, not sure as to why I had the problem.
Tim
