1. bludove
  4. Monday, 22 January 2018
I am getting the following showing up in my error log:
PHP Warning: Invalid argument supplied for foreach() in .... /templates/j51_chelsea/php/styles.php on line 319
Here's the line in question:
<?php foreach ($moduleoverrides as $item) : if($item->module_position != "0") : ?>
Not sure how to resolve that one. Can you tell me how I should fix this?
I received your email that the issue was resolved with the latest download. I downloaded Chelsea, installed and I'm still getting the exact same error.
[26-Jan-2018 03:09:27 UTC] PHP Warning: Invalid argument supplied for foreach() in /home/tbcgvill/public_html/templates/j51_chelsea/php/styles.php on line 319
In fact, I checked the code on line 319 and it's still the same as before. So something still is not right.
Please advise
Similar issues are happening with Enlighten template on another site.
We updated the Ashley template which you inquired about an error in a separate email.
There error suggests and empty array which can happen if no template data is saved within your database. The error should have resolved itself once you saved your template settings however I see from the timestamp on the error that this is probably not the case.
As you are unable to allow us access could I ask you to post a screenshot of your Module Style Overrides template settings tab.
