1. ET
  3. Thursday, 13 July 2017
Wondering if there would be any reason that I cannot add an iframe within an article with the template. I have tried the standard fixes in the TinyMCE prohibited elements. But the iframe keeps getting stripped.
Hi ET
There is no reason that I am aware that would not allow you to use iframes within your template. Does the issue persist if you enable one of the default Joomla templates (Protostar)?
Just gave that a try. Same problem apparent with Protostar. I'll keep looking.
Thanks for the tip. Got me thinking again... Worked it out... Silly me... Didn't realise I needed to click on the correct Set (Set 0) within TinyMCE and make the change to prohibited elements there.... All Sorted.
