1. Drew
  4. Friday, 15 March 2019
Ciarán,
Is it possible to make the Icons Module Example 1 or Example 3, have an Opacity/Transparency (Naomi Template)?
I tried the following for a Module Class Suffix, with no success:
.transperancybackground {
background-color: rgba(76, 175, 80, 0.3);
Any suggestions please.
Thank you.
Hi Drew
Replace 555 with your modules ID (Module Manager - Right column)
.j51_icons555 .j51_icon {
opacity: .5;
Wonderful. Thank you!
I was thinking it would not effect the text color as well.
Is it an option to retain the text color without opacity? Or Adjust to be darker?
Thanks again.
- Drew
Hi Drew
To just affect the background color you can use something like the following...
Edit to taste
.j51_icons555 .boxed figure {
