1. regenbogen51
  3. Monday, 12 September 2022
I have a question regarding the main menu. I would like to place an icon next to a main menu entry, when there is a sub menu (like a downward triangle). Using the icon class, this already works well. However, the icon appears left of the menu entry. In your demo templates, the icon is located on the right of the menu entries. How can I solve the problem, so that the icon appears on the right side? Is there a manual available?
Further, I noticed that in the mobile version the small icon is located above the menu entry. Here, it is not necessary (in fact, it is disturbing the layout). Is it possible to remove it from the mobile version? Is there a manual available?
Thank you for your answers.
Best regards
Iris
Attachments (3)
Hi Iris
Would you have a URL to an example of your menu?
thank you for your answer. I have createt an example of the issue:
https://menu-exp.seebens-guw.de/
Best regards
Iris
Thank you Iris
.hornav .parent > a > .fa-caret-down {
order: 1;
margin-left: .25rem;
.hornav .parent > a {
display: flex;
.mm-ocd .fa-caret-down {
display: none;
Perfect! That's it.
Thank you very much!
Iris
