1. cybork42
  3. Saturday, 27 February 2021
Dear Support.
I have been trying to make my site use the carousel navigation not above the news items but below, as your template demos show. Howeber, I cannot get this to work. What's the trick, and where is it to be found to achieve this?
See attachment from your template demo (nvaigation) and my output (navigation2).
Please help me on!
Thanks and best regards, Andreas.
Hmmm... it seems I solved the issue just by playing around.
I deleted the module and re-created it, and voila, now the navigation sits below the intro images.
Miracle? Probably rather some glitch?
Thanks a lot anyway!
Andreas.
Thanks a lot for your quick response.
You can find the content and described behaviour (issue: carousel navigation above images, won't go below these) with this site:
https://www.schwaben-tech-park.de
The mod51_jnews config tab is attached to this email. I guess I made it just the way it should be?
Thanks a lot for helping me on!
Andreas.
Hi Andreas
Would you have a URL to an example of your Carousel navigation?
