1. ltoptas
  3. Wednesday, 21 January 2015
HOW TO CREATE MULTILANGUAGE WITH THIS TEMPLATE - J51_Central
LANGUAGE SWITCH SELECT RUSSIA, NOT SHOW MENU.
BECAUSE TEMPLATE MENU TAB ONLY ONE LANGUAGE
You have 2 possible options..
1. Select a Template style in your 'Template Manager' (Eg. Central - Default) and duplicate it for each language you want. In each of the styles then select the menus to be displayed for that language. You can then set that template style to the langauge via the 'Languages' dropdown or by assigning the correct menu items via the 'Menu Assignment' tab.
2. Within the templates parameters you will see an option to convert the menu to a module position. Once selected you can then create a menu for each language set to the 'hornav' module position.
