1. gphood
  3. Thursday, 22 December 2016
Hi - I'm using the Nadia template on a site I'm building at http://eb.granthoodtest.co.uk but I have an issue with the responsive menu, specifically the Hornav in the mobile view. Any menu items that have sub-menus are no longer clickable as links. Because the sub-menu toggle anchor is wrapping the entire menu item rather than just the arrow icon, the link for that parent menu item is no longer working. All you can do is toggle the sub-menu on or off.
If you're not sure what I mean, go to http://eb.granthoodtest.co.uk on a smartphone and try clicking on either the Home or Our Services menu items. On a larger device clicking the main menu item would take you to that page. On a mobile, all it will do is reveal//hide the sub-menu, so it no longer works as a menu item in its own right.
If I can figure out where the hornav menu is generated I'll have a go at re-writing how the HTML is formed so the wrapping anchor is only around the arrow icon, but I'm not sure where it is.
Can you advise please?
Thanks a lot - Grant
  1. http://eb.granthoodtest.co.uk
Hi again - I found the information for achieving this in the template notes about 30 seconds after I posted the question. https://www.joomla51.com/tutorials/item/mobile-menu-linking-parent-items
