1. Ciaccio
  3. Tuesday, 15 March 2016
I have a multilingual site , but in the mobile does not display the sub-menu items . I followed the instructions of the template they say
"Converting menu to a Module Position
When creating a menu module for the hornav module position ensure to add moomenu to the Menu Tag ID field of your modules parameters. This enables the animated dropdown menu as seen on our template demo.
If creating a multi-language site a duplicate menu module needs to be created for the responisve mobile menu. Duplicate each language menu module setting the position to hornav-mobile and set the Menu Tag ID to mobile."
but it does not work the same .
Can someone help me?
Hi Ciaccio
thanks for the reply , the URL is
http://pcfotoweb.it/agri_2
submenus that give problems are ABOUT-US and SERVICES in mobile version
Pier
Thank you Pier
There appears to a be jQuery conflict. Firstly ensure that jQuery is disabled within your slideshow modules parameters. If already disabled may I suggest sending temporary administration access to your Joomla installation to [email protected] and we will examine this issue further. For our reference please paste a link to this post in your email.
Thank you Pier
We have installed the 'jQuery Easy' plugin (http://extensions.joomla.org/extension/jquery-easy) which ensures only one copy of jQuery is loaded across your site. This appears to have resolved the issue.
Thank you so much!!
You've been really helpful , thanks again for the help . :laugh: :laugh:
