1. Cinderella
  3. Tuesday, 10 May 2016
Hey,
I use the boutiqu51 template and i´m a joomla beginner.
I have put the "hr-underline-from-center" in link css style. This works :)
Now i want to change the font color at the same time and change the background color from the drop down menu.
How can i do this?
Hi Cinderella
You will find an option to edit the font color and dropdown background in the 'Menus' tab of your templates parameters. From your Joomla administration navigate to Extensions -> Templates -> [YourTemplateStyle] -> Menus.
Where exactly i have to to put in the hr-underline-from-center code in the template css?
You don't need to touch your template css. hr-underline-from-center is a class and can be placed in the Link CSS Style field.
From your Joomla administration navigate to your menu item settings, select the Link Type tab and add the following to the Link CSS Style field.
Thank you for your advice, i have entered the parameter as you told me, unfortunatly there is no effect.... :( did i have to define a picture to the link?
best regards
Hi Donald
Thank you for your answer, but i found the Mistake, there was a Misstyping, Cinderella wrote hr-underline-from-center instead hvr-underline-from-center now it Works Perfect.
